Antex Z1/Z1e ?
First post, by cyclone3d
Anybody here ever use or even better yet own an Antex Z1e?
I was looking at some other Antex cards and noticed that the Z1/Z1e has OPL support of some kind. I would be interested in getting one of these old cards.
I haven't even been able to find a picture of it.
Edit:
It also has a 2MB wavetable daughtercard as well as joystick/MIDI port.
See here for a small bit of info.
https://books.google.com/books?id=eMKimy4DFaE … x%20z1e&f=false
https://books.google.com/books?id=RjY3gFmnC8U … ex%20z1&f=false
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1 of 6, by peklop
I found PCMAG reviews and searching for info too.
Card is only FM with Ensoniq OTTO wt db?
TMS320C25 DSP is for what? For MPEG compression?
here i found Antex manual:
https://www.scribd.com/document/324516037/ANTEX-Sound-Cards
Z1 card ID is 19
Z1E card ID is 27
from 1996 site:
Z1E:
https://web.archive.org/web/19961028092955/ht … /specs_z1e.html
https://web.archive.org/web/19961028092813/ht … m/prodguide.pdf
https://web.archive.org/web/19961028092759/ht … /prodguide.html
Antex Z.Wav Plug in 16-bit wavetable MIDI sound module for Antex Z1e digital audio adapter. General MIDI compatible, Z.Wav features 32-voice polyphony and 16-part multitimbral capability with 4MB of sampled sounds $195
Reply 3 of 6, by peklop
Here are drivers and sdk.
Source: https://groups.google.com/forum/#!search/ante … Ss/4NNXXYjUGwAJ
Antex Software Development Kit for Intel Platform
https://web.archive.org/web/20031005012738/ht … K_i386_V332.exe
Antex Application Software
All Windows Operating Systems (except DOS & 3.1)
Download the latest version of the Mixer, Demo, and Meter. apps-v1058-x86.exe (644k)
https://web.archive.org/web/20031005012738/ht … s-v1058-x86.exe
Support: SX-3, SX-7, SX-9, SX-12a, SX-20, SX-22, SX-23e, SX-33 and Z1e. File: 95drv400g2.exe
https://web.archive.org/web/20031005012738/ht … /95drv400g2.zip
Reply 4 of 6, by cyclone3d
I found and bought this Antex SX-33 a while back. Pretty sure it uses the same board as the Z1/Z1e. Even a place for an OPL3 chip.
The attachment Antex SX-33 front.jpg is no longer available
The attachment Antex SX-33 left.jpg is no longer available
The attachment Antex SX-33 right.jpg is no longer available
The attachment Antex SX-33 back.jpg is no longer available
YMF7x4 Guide
Reply 6 of 6, by GL1zdA
Found a poor quality photo of the z.wav daughtercard. You can read about it more in Radio-World-1994-09-07 and Electronic-Musician-1993-10. It's another Waveblaster compatible board. Contrary to what's in the PC Mag review, it's written, that it contains 4 MB of samples, which would make it bigger than on the other Ensoniq OTTO based boards. The PC Magazine review linked in previous posts mentions it "lacked the sparkle found on other chipsets" which to me describes the Soundscape, so they might have used a similar sample set. There's no editor, so it looks like it's limited to General MIDI operation.
There's one additional quirk, the daughtercard has more than a WaveBlaster connector. If you look in the Antex sound cards Manual, you can see, that it connects to a Z1/Z1e card via a Waveblaster header (J2), a "MPU-401" header (J11) and a DSP header (J12). The SX-3/33 on the other hand use only the "MPU-401" header and the DSP header, so apparently there's no Waveblaster compatibility. A dedicated DPS connections sound similar to the optional DSP on a Soundscape Elite.
getquake.gif | InfoWorld/PC Magazine Indices
