I received the board today. The thing is insanely large and complex. I did some research and it seems that it came from UNISYS PW2 800 20C computer. Thankfully, the board does seem to fit AT standard so I will probably be able to fit it in some ordinary case.
The board has integrated parallel and serial controller (WD brand). I will try to start this giant this evening and let you know.
For now, I have the following questions:
- what do you think is the socket in the centre of the board? It resambles VLB extension socket, but it's definately not the case here.
- where should I look for any resources, like jumper settings? For now I will not touch any jumpers and dip switches, as I have no idea what they do.
- It seems to be the first revision of the board. Do you think the cable patches are the signs of repair or just some late design changes on early stage of the product? Could be both, but I just wonder.
