First post, by feipoa
- l33t++
I'm putting together an order for brushless DC [computer] fans of varying sizes.
The smallest is for a 100 MHz 386 (IBM BL3). The fan size is 25mm x 25mm
Next smallest is for a 386 heatsink (SXL2-55) and for a QFP AMD Am5x86-160 (on Evergreen upgrade board with a small heatsink). The fan size is 30mm x 30mm.
Next in size is the standard 486 fan size of 40mm x 40 mm, and so on...
These are small fans and I see various CFM and dB/dB(A) listings for all of them. I see some 30x30 mm fans with noise up to 23 dB. For my standard case and CPU fans of 80mm x 80mm, I usually go for noise in the 20-22 dB range. I hate fan noise. But is the pitch and volume of an 80mm x 80mm fan at 22 dB the same as that emitted from an 22 dB 30mm x 30mm fan?
