First post, by clueless1
- l33t
Looking to replace the stock Intel cooler on my Xeon X3230 because idle temps are in the low 60s (which I understand is normal for this CPU with stock HSF). Once summer hits, I wouldn't be surprised if idle got close to 70. So far these are what I've found:
Cooler Master Hyper TX3 for $23:
https://www.bhphotovideo.com/c/product/937158 … ooling_fan.html
and Evercool HPFI-10025 for $18:
https://www.newegg.com/Product/Product.aspx?I … 9-090-_-Product
CPU is not overclocked due to Intel motherboard having no OC options.
Anyone recommend one of these over the other or have a better choice for <$25?
EDIT: cleaned dust out of the case exhaust and the idle temps are down to about 55c. Temps dropped to 51c when the side panel was off.
