Sorry for the late reply I was away from home. I will update this message when I get the pictures and information gathered 😀 Thanks.
Edit: Alright just to show what started the problem:
The attachment imageedit_1_5327205520.jpg is no longer available
Here on the General tab I have changed it earlier by unchecking one of the boxes. Afterwards I rebooted the PC and booted up like normal.
What changed was something related to the display's driver. That unknown device message showed up. At the time I wasn't thinking and I selected some driver from the list that I thought was what it needed. OK. I reboot again to take changed and boots into the system just fine. The startup programs are now all coming on until a message/error about my video adapter came up and the system restarted itself. Ever since then whenever I try to boot into the system, it just hangs/loads forever on the win98 screen.
Diagnosing:
What I have tried so far:
- The picture above is the CURRENT settings meaning I have tried to isolate the possibility that the problem was being caused by this. Even with everything unchecked I still cannot get passed the loading screen. This led to the problem, but have not caused it.
- I have looked at the bootlog.txt and found a loadfail referring to some/all fonts failure code being 0016... I looked that up and it seems there has been a pattern of people realizing that it has nothing to do with their problem 🤣. It's normal. But people have mentioned video cards/adapter/driverish issues...Leading into further discussions about IRQ and plug n play stuff..
Theories:
That damn display driver or whatever driver I put in for the system to use when I disabled that stuff on that utility has to be the cause. And the part where I vaguely remember S3 crying about something before it kept on failing is kind of my only lead atm.
I want to try to reinstall these drivers relating to displays/video cards but it's being a bit of a hassle at the moment. Any thoughts?
