First post, by TheAbandonwareGuy
http://http.download.nvidia.com/
The sheer amount of stuff there. My god that appears to be everything that would normally be in the many broken links on there website.
This is the first time I've seen that FTP server working correctly. I found it while hunting for the 30.82 detonator drivers. That not just drivers
though I'm seeing quakecon stuff, demos, render slides. The amount of data here is massive. I'm even seeing OEM specific drivers and some of the
first ever RIVA drivers.
No telling how long it will be available and correctly functioning. I think we should grab it, make a RAR file, and throw it onto vogons drivers.
My nets too slow or id archive it myself. Anybody want to help grab everything while its there.
Cyb3rst0rm.com: Here There Be Screeds https://www.cyb3rst0rm.com
Reply 1 of 22, by fitzpatr
I'm pulling it now. My 100Mbps line should make short work of it.
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 2 of 22, by keenmaster486
Excellent.
World's foremost 486 enjoyer.
Reply 3 of 22, by Rhuwyn
I'll grab it took as soon as I can. Not in front of a machine that can hold it all right now.
Reply 4 of 22, by TheAbandonwareGuy
Alright. Be careful not to hammer the server to death.
Reply 5 of 22, by elod
Grabbing the Windows folder. Anything else of interest?
Reply 6 of 22, by TheAbandonwareGuy
There are downloads scattered through out all the folders along with videos and images that would likely be of interest. I'd recommend grabbing as much as you can.
There's an IRC at https://webchat.freenode.net/ under channel NVIDIA101
Lets coordinate in real time there. Use your vogons username as ID so I know who you are.
Reply 7 of 22, by spiroyster
wget o.0
Reply 8 of 22, by fitzpatr
spiroyster wrote:
wget o.0
Indeed. I'm at 80GB.
486 Build
Reply 9 of 22, by MrMateczko
This address was working for a long time now, I've discovered it months ago.
Weird they still hadn't patched it up 😀
Reply 11 of 22, by keenerb
Upload a directory listing...
Reply 12 of 22, by deleted_Rc
Considering half a Tb that's going to take a while when done right....
Reply 14 of 22, by keenerb
Just what I was looking for. Thanks.
Reply 15 of 22, by DosFreak
cyclone3d wrote:
I did a "dir /s" listing. Is there some better way to make one that is more readable?
I also did a Tree listing
You can try PowerShell:
gci -recurse | select fullname | export-csv output.csv
Remove | select fullname if you want all the details
Make your games work offline
Reply 17 of 22, by WR3ND
What is there to patch?
Working as intended. 😘
On a side note, I wouldn't mind hosting FTP stuff for distribution, if it wasn't a pain in the rear end. Not even worth it for me unless it's only over a secure local network. 😢
Reply 18 of 22, by leileilol
cyclone3d wrote:
more readable?
dir /s /b
