First post, by AppleDash
- Newbie
I have a MS-5184 socket 7 motherboard that has both ATX and AT power supply connectors. I have just transferred it to an ATX case so I can free up one of my AT cases for a different build. However, I'm experiencing a problem. The system works just fine on the AT PSU, but on the ATX one, it does not. The CPU fan still spins up, power LED lights, but it does not POST and I get no video. As soon as I switch back to the old AT one, it works fine. The ATX power supply has -5v support, and last it was used it is known good. As far as I can see in the motherboard manual, it will just support ATX out of the box with no jumper changes (and I see no jumper nearby on the board.) Any ideas?
Main retro system: Am486 DX4 100MHz | 128K cache | 16MB RAM | VLB Mach32 | Sound Blaster 16 | HardMPU w/ MT-32 or SC-55 | MS-DOS 6.22; no Windows
