First post, by zerker
- Member
So I found out the DOS MODE command allows you to theoretically redirect a parallel port to a serial port. This is potentially great, as I can just capture the serial output on another machine via null modem and save formatted print output to disk.
Trouble is, it doesn't seem to work. I initially run the command and the output looks promising:
> mode lpt1=com1LPT1: rerouted to COM1:
But as soon as I check the general mode status again, it says it isn't redirected after all.
> modeStatus for device LPT1:-----------------------LPT1: not reroutedRetry=NONECode page operation not supported on this deviceStatus for device LPT2:-----------------------LPT2: not reroutedStatus for device LPT3:-----------------------LPT3: not reroutedStatus for device CON:----------------------Code page operation not supported on this deviceStatus for device COM1:-----------------------Retry=NONE
If I try to print via MS DOS Edit, or manually redirect a command output to LPT1, it fails just as before. Redirecting a file to COM1, or using a program with serial printing (MS DOS Help) works as usual. I do, of course, already have the mode configured properly for COM1 itself.
I'm running official MS-DOS 6.0. Any thoughts or suggestions? Anyone else tried this sort of thing?
