First post, by cyclone3d
It has been quite a while since I have had a system with only ISA and/or ISA/VLB slots.
Regardless of whether or not the board has onboard drive controllers, what is the most compatible replacement storage via adapters?
I would guess it would be CF since it is PATA based.
How about IDE to SATA adapters? Anybody tried one on a 486 or older system? How does it deal with the drive size limitations.. or does it?
What do you use?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1 of 9, by chinny22
CF if tried and tested, It's what I use.
SD also seems to be getting more popular
I use a SATA adaptor in my xbox which in some ways is more sensitive then a PC as loading to the dash is timed and that split extra second some adaptors take causes trouble, Where as a PC is a lot more forgiving.
Most (if any) wont do anything for size limitations, its simply changing IDE to SATA, of course you could use drive overlay to have a massive sata drive usable in a 486 if you wanted.
Reply 2 of 9, by brostenen
There are multiple choices. Some have been named, though I will put them in my list as well.
- CF cards.
- SD to CF card adaptor in CF to IDE. Yes they excist, have not seen them named on Vogons before.
- DOM modules. (Disk on module)
- SD card's.
- Micro drives (slow)
Of course you can source old IDE drives, or you can use SCSI. Most of it are old, unreliable, expensive or will not last forever.
Reply 3 of 9, by dexvx
There are also SD -> IDE, without need of SD -> CF. However, at the moment only sellers in China sell them, but they are about the same price as a CF -> IDE adapter.
For me, SD cards are more ubiquitous (less cost) than CF.
Reply 4 of 9, by PhilsComputerLab
I used CF cards in the past, but these days I've moved to SD cards with an IDE to SD adapter and that works great for me.
But like said before me, there are lots of options, which is a great thing 😀
YouTube, Facebook, Website
Reply 5 of 9, by derSammler
I wouldn't recommend using SD cards as a hard disk replacement, as they are slow and have a very short life time. CF cards are much more durable/reliable. And, as already written, CF cards are native IDE/ATA, so there's no signal or protocol conversion involved.
The only issue you may find is that many CF cards don't have the fixed disk bit set and most BIOSes from 1994 and earlier won't boot from removable media. DOMs are a good alternative in such a case.
Reply 6 of 9, by gdjacobs
They're not as resilient as SSDs designed for heavier write cycles, but they would be fine in any situation where disk swapping wasn't a factor.
Reply 7 of 9, by cyclone3d
Thanks for all the info so far.
Here are a couple more questions.
1. CF card vs SSD durability? Is it really going to matter? I do have a few SSDs laying around and will probably end up using them before I move to CF if I ever do.
2. Are there any IDE to SATA adapters that are better than the cheap Chinese ones? The cheap Chinese ones are about $2 each. I can get some fancier ones that have LEDs and possibly a different chipset (JMicron 20330) on them for $3.25 a piece if I buy a lot of 6. What chipset do the cheap Chinese ones use? I can't tell from any of the pictures I could find.
2. Anybody ever tried a 500GB IDE HDD on a 486 setup? I have a WD one. I am still waiting on hardware to get here so I can't test myself yet. I know it would be totally pointless. I probably couldn't find enough software I would want to run on a 486 that would fill up a 500GB drive.
3. What drive overlay would be the best?
YMF7x4 Guide
Reply 8 of 9, by gdjacobs
The cheap IDE to SATA adapters are fine.
Reply 9 of 9, by creepingnet
For the time being I'm just using Drive Caddies on my 486 and soon my Tandy 1000 (and maybe the 286 as well) filled with bigger than normal hard disks.
Tandy 1000 = 8GB WD EIDE
GEM 286 = 540MB EIDE w/ DDO
486 = see below...
15GB = MS-DOS 6.22/WFWG 3.11
20GB = Windows 95 OSR2 C
40GB = Windows 98 SE
80GB = have not decided yet but leaning towards Windows 2000 Professional
~The Creeping Network~
