Motherboard form factors
First post, by Baoran
Is there a motherboard form factor that is older than AT motherboards and uses different screw hole placement than AT/Baby-AT motherboards?
I have a big case where I would like to put an baby-AT 386 motherboard, but I am having some trouble.
Reply 1 of 11, by Errius
may be something proprietary?
Is this too much voodoo?
Reply 3 of 11, by Baoran
I think there might be something wrong with the motherboard itself that I think should have been baby-at size. It has alot of those small holes meant for plastic clips instead of screws and they are positioned differently than standard AT screw hole locations. I thing I would only be able to use 2 screws to attach it to the case itself.
Reply 4 of 11, by Deksor
It happens more often than you think. My 486DX4 is only having one screw, and my other 486 used to have only one too, until I changed it's case. Cases doesn't always have every screw holes that they should have
Reply 5 of 11, by Jed118
I have only one screw holding my VLB 486 board to the underlying plate, my 386 is the same way, and as is my Pentium. The only one that's a little different is my 386 in an XT case (top pops open type) which has two brass screws.
What's for sale? my eBay!
Reply 6 of 11, by firage
Two screws and two sliding plastic standoffs on all my Baby-AT boards.
My big-red-switch 486
Reply 7 of 11, by Baoran
The attachment 20170423_101647.jpg is no longer available
If I put a plastic standoff to the left one at back of the case and a screw to the other one in the middle of back of the case, they match with the holes in the motherboard, but if I put plastic standoffs to the other 2 that are further away from back of the case, those plastic standoffs would be about 1cm too far away from back of the case to match the holes on the motherboard. How would you put motherboard in the case?
The motherboard that I am trying to put in the case is the one I am talking about in this thread: 386 KMC-A419-8 motherboard and ram
Picture: http://www.amoretro.de/wp-content/uploads/kmc … d_ali_m1419.jpg
Reply 8 of 11, by Errius
That's an XT case? Can you put AT boards in XT cases?
Reply 9 of 11, by Gamecollector
Baoran wrote:
2 holes in the 2nd row (G and H) are incorrect. They are similar for AT, Baby-AT and ATX boards and must be 6.5" from the front edge of a MB (6.1" from the 1st row of holes). In other words - they must be below ISA slots, not between.
This MB not meets the Baby-AT standard.
Reply 10 of 11, by Baoran
It had a huge 286 motherboard 31x35cm when I got the computer and I would have wanted to upgrade it to 386
Reply 11 of 11, by Baoran
This is what originally came with the case. As you can see there is alot of corrosion.
The attachment 20170423_121053.jpg is no longer available
