First post, by bluejeans
My goal is to have all the mainstrem cpu speeds that an average person would have had from upgrading every few years. So far I have:
486 dx/33 (with 50 and 100 cpu's laying around)
Pentium 133
celeron 300
p2-450 (laptop)
p3-700
celeron 1ghz (in a point of sale machine, ddr2 memory so relatively recent)
intel atom n450 1.5ghz
athlon 2200xp
core duo e2160 1.8ghz
core2duo t7700 2.4
(not interested in speeds from this point onwards but for the sake of completeness...)
core2quad 6600
i7-870
i5 4690k
Imo it's a pretty good assortment to have different speed systems at regular intervals up to the present day. Obviously missing out on pre-486, and pentium 1 - I have a board that would let me underclock the 133, and it's fitted with a 166, but it's dead. Main reason I don't just use slowdown programs is because they seem to make doom actually slow, and not just jerky/low framerate.
Also, if I wished to share a hard drive between several systems, would windows 95 be the latest o.s that can handle being started on completely different systems without spitting chips? I know for sure that xp and onwards will blue screen with so much as a different motherboard. I've started 95 before accidentally on a different system and it seemed to cope.
And if I share it between all the systems enough, will it eventually autodetect and install the different video etc drivers, since they'd be on the hard drive from before?
Reply 1 of 17, by Koltoroc
ditch the atom. Nobody would have gotten one as an "upgrade", particularly not in the spot where you put it, because it was MUCH later (around 2010) and pretty much only used in netbooks.
I would replace the celeron with 1GHz with an Athlon 1000 (first GHz CPU, more powerful architecture in general compare to intel, first time AMD was more powerful than intel in general), and the Athlon XP with the athlon 64 Sledgehammer/Clawhammer/Newcastle (first consumer level 64 bit CPU, More powerful than higher clocked Intel P4 CPUs, first time memory controller on the CPU). I guess you could put the P4 Northwood between those two, as it was reasonably powerful and quite common at the time.
Reply 2 of 17, by 386_junkie
Was the jump from 16-bit 286 to 32-bit 386 not mainstream?
I could understand maybe ditching the 286 as it's not a 32-bit CPU but not having a 386 there!?
Where did the 486 come from?... what would the average person do before the 486?
Reply 3 of 17, by firage
I agree with a 1.0-1.4GHz Athlon being more interesting than the Celly or Atom in that spot, but they do the job. I think you're missing a high end single core CPU, around 3GHz+, could be an A64.
My big-red-switch 486
Reply 4 of 17, by kixs
Depends on what are you after. Some go the same route that they went originally. Some prefer top cpus at the time.
I'd go the same route as my upgrades... 286-16, 486slc-33, 386DX-40, 486DX2-66 (@80), P-90 (@100), P-166MMX (@250), AMD K6-2 500, P2-300 (@475), Athlon XP 1800+, Athlon XP-M 2500+ (@2500), Athlon64 X2 3800+ (@2500), Phenom X6 1055 (is still in my main desktop).
Sharing a hard drive isn't good idea after DOS even if it might work in some cases (but it will take a lot of time installing drivers).
Reply 5 of 17, by Ampera
My current very sparse setup is
DX4-100 (120Mhz)
Pentium 3 450Mhz
A P4 machine of some sort
Athlon XP+ @ something or rather
2x Athlon 64 (Might be a bit newer)
I suggest for you, throw of course a 386 in there at least, a better 486, and IMO some P4 machine
Reply 6 of 17, by Almoststew1990
I would recommend the i7 860 as it was substantially cheaper than the i7 870, whilst only being 100MHz slower (if I recall correctly) and would be a more attainable jump achieved by a greater number of people (typically from the C2D CPUs).
Reply 7 of 17, by dr_st
You could definitely add some high-end (>1GHz Pentium III), a P4-HT, and an Ahthlon64.
Reply 8 of 17, by Skyscraper
I think an i7 920/940/965 is a better choice than an i7 860 or 870!
in Sweden pretty much everyone with an interest for hardware jumped on the Socket 1366 victory train and many of us are still riding it. Around here Socket 1156 mostly sold in the form of OEM and pre built systems.
edit: 6 ---> 9
Reply 9 of 17, by bluejeans
In terms of speed, wouldn't the athlon xp cover the gap between 1ghz celeron and p4 3ghz? Just looking at the sheer speed aspect of things.
Reply 10 of 17, by bluejeans
I thought the p4 prescott was almost the fastest single core at 3ghz.
Reply 11 of 17, by dr_st
That depends on the level of granularity you want. Since you are also considering mobile CPUs, a ~2GHz Pentium 4-M can be interesting.
Reply 12 of 17, by Scali
Why?
I think the same can be said for the i860 and i870. They are virtually the same performance (actually, even slightly better: http://www.anandtech.com/show/2839/7), and many people (including myself) are still using them today, as the base performance level is still quite acceptable.
The advantage of the i860/i870 could be that it has lower power consumption and only needs two matched DIMMs (dual channel) instead of 3 (triple channel).
Reply 13 of 17, by Skyscraper
Scali wrote:
Why? […]
Why?
Simply because they were released first.
To me at least an overcloked i7 920 @~4Ghz was a real game changer. I had an E8600 @ 4+ GHz for a few months before I upgraded (and an E6750 @ 3.8 before that) to Socket 1366 and while I did not see much difference in gaming (read World of Warcraft) I do also do other things with my computer. 😀
Reply 14 of 17, by elianda
The goal depends obviously on your intended upgrade cycle length. In brackets if you want more steps.
8088 4.77 MHz
[286-8]
286-12
[386SX-16]
386DX-33
[486SX-25]
486DX2-66
[486DX4-100]
Pentium 100
[Pentium 233 MMX / AMD K6 233]
Pentium Pro 200 or Pentium II 266 MHz
[Pentium III 450]
Slot Athlon 600 - 800 MHz
[Athlon TB 1.4 GHz 133 FSB]
Pentium 4 Northwood 2.4 GHz with HT
[Athlon XP 3200+]
Core2 Quad 6600
Youtube Channel
Reply 15 of 17, by tikoellner
I would still consider going down and getting XT class machine and 386.
There is a potentially huge gap between 386 and 486 class machines.
XT gaming capabilities are limited to 80's software, but it makes this machine even more interesting if you aim at creating a collection of machines that each belong to different era.
I would also skip DX33 and use DX2-66 instead along with 386 machine.
Reply 16 of 17, by Scali
XTs are interesting because they are so different from ATs, it's almost a different standard.
Different keyboard interface, only 8-bit ISA slots, one DMA controller, one interrupt controller, no standardized realtime clock yet, no CMOS setup etc.
I think you should either go for a real IBM, for 100% compatibility, or for some turbo XT clone, which can run at 4.77 MHz and at 8-10 MHz. The ~10 Mhz XT is another interesting standard, especially when coupled with EGA or VGA graphics. You can play some interesting games like Prince of Persia or Commander Keen on them.
Reply 17 of 17, by tikoellner
I love IBM 5150 (PC) and 5160 (XT) machines (I owe one 5160). Nontheless, deciding on an XT class machine I would go with some turbo clone. It's really hard to imagine how slooooow the original XT really is.
Don't event think of playing Prince of Persia on a stock machine. It's way to slow.
Upgrading IBM XT in terms of speed is rather tricky (simply replacing i8088 with NEC V20 is just not enough) and expensive (there are some turbo cards, but they're hard to get. I'm looking for one myself).
Turbo XT would surely run a much wider range of games, especially when EGA graphics is in question.
