First post, by Phreeze
The attachment IMG_20170427_172837.jpg is no longer available
Hi there,
i recently got a V5 AGP. Fans turn, but i get no image. I tested with 2 boards and Pentium3 Slot1 CPUs: one with an via apollo chipset and one with a BX i440 chipset. At least the apollo one has "agp 2x enabled" in the bios.
WHAT can i check ? (The boards work fine with pci and agp cards).
"Optical check" and "smell test" were ok 😒
ArGUS Parts list: http://bit.ly/2Ddf89V
Reply 1 of 5, by F2bnp
Perhaps the contacts are a little dirty. Try rubbing them with an eraser or an earbud + alcohol. Other than that, you could also clean the molex connector on the top right. If that doesn't work, I suggest taking a good look at the card to see if there are any missing capacitors or SMDs, there are some very high quality photos of the V5 online that you can compare with.
If all of the above fail, you try baking the card, but the results will vary 🙁.
Reply 2 of 5, by Phreeze
another idea by myself:
what AGP voltage does the card use?
I have to check of my boards can provide the correct voltage
I'll check the contacts, but I think they very clean. I have experience in cleaning them as I collect old videogames^^
Reply 3 of 5, by meljor
Every slot1 board will be working with any voodoo so agp voltage is not your problem here.
Check all the tiny components.
Reply 4 of 5, by AzzKickr
You should best contact Oscar and have him have a look at it. Are you located in Europe ?
Heresy grows from idleness ...
Reply 5 of 5, by nforce4max
Lets hope the previous owner didn't plug it into the wrong sort of board. You could try booting with another card and this 5500 plugged in to see if it is detected at all.
