First post, by Ampera
So I downloaded Daggerfall off Bethesda's website, and installed it onto my rather overpowered Pentium 3 450Mhz Windows 98 PC
I proceeded to then burn the DFCD part of the file onto a CD with the directory contents looking as such:
http://prntscr.com/f3hye9
And I made sure according to these instructions:
https://www.dosbox.com/wiki/GAMES:The_Elder_S … _II:_Daggerfall
to set the label to Daggerfa
Please note that I am NOT using a CD for this, I am using a DVD+RW, and that the drive, the disc, and the machine are all known working and good.
What am I doing wrong?
Reply 1 of 4, by Jorpho
Perhaps you have the wrong filesystem set? I don't know what burning program you are using, but In Imgburn, you might have to manually set "ISO9660 + Joliet".
Reply 2 of 4, by keropi
I seem to recall that by editing some paths in a cfg file (dagger.ini ?) you can make the game work without a cd , maybe that's something to investigate?
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 3 of 4, by Ampera
http://prntscr.com/f3obph
Reply 4 of 4, by keropi
It's Z.CFG , edit that to reflect your CDROM path, IIRC Bethesda offers a version that has this file altered so the game runs completely from HDD.
I believe this gets created by the cd-rom installation program once install has finished.
Also my original EU CD has a volume label of "Daggerfall" - doesn't matter though as the game uses Z.CFG to locate it's files.
