First post, by bluejeans
I'm running an ide to sd card adapter and I'm running out of sd cards that will actually work in it, seems to demand both sandisk cards and microsd adapters. I accidentally started windows on system B, when it was installed and configured for system B. It seemed to work alright apart from having to load some drivers on startup - I think even the onboard video is identical. Will I run into problems by "sharing" the install like this?
Reply 2 of 2, by Tetrium
To me, it worked fine most of the times for testing purposes, provided it was a 9x install. I used to do this regularly back when people were tossing out old rigs like it was trash (mostly to check if the harddrive was still functioning).
For my own rigs, I prefer a new install on each separate rig, even though it is more time consuming.
My retro rigs (old topic)
Report spammers here!
