First post, by iKarith
- Newbie
I just received an EFA Viking 3, my second super socket 7 board. It doesn't recognize the K6-2+ CPU without a BIOS update which has not been installed yet.
The video card comes up, the board tests the memory, etc, and then hangs here:
The CPU is a K6-2+ 550, but at least one source claims the board only supports up to a K6-2 475. I've tried setting voltage to 2.0v and 2.1v, and you can see I've dropped the multiplier here just in case that was necessary. It always stops here and multiple keyboards have LEDs flash when the system powers up. It doesn't try to access drives either.
The eBait seller said the board was tested to POST, so I'm wondering if there's something I can change out? I'm the cost of two motherboards into this project, as well as pretty much all of the other components actually, so I'm pretty bummed at this point. The last board wouldn't recognize any drive or even boot a SATA controller. This one isn't even getting that far.
