First post, by sketchus
Hi all,
I've been tinkering with Quake 2 on my system which is:
ABIT BH6
SL5XT CPU @1.1GHZ
256mb RAM
TI4200
Win98SE.
I have a very odd problem where the game is absolutely buttery smooth as long as I don't hold two keys together. I can walk forward with no drops and I can turn with no drops, but both together causes massive dips down to 30fps.
If I watch the timedemo though it doesn't have the issue, it works perfectly and stays around 90fps no problem. So it must be something to do with my keyboard but I can't figure what? I've tried two keyboards, but they are both USB, and I tried switching keyboard support from bios to OS but no luck.
Anyone encountered anything like this before?
Reply 1 of 4, by Rawrl
Huh, I've never heard of anything like that before.
Have you tried a PS/2 keyboard, just to see if it's a problem with USB?
Also, given it's a Slot-1 era Abit board, the capacitors are automatically suspect. Have you changed them out? Bad caps can cause all sorts of problems, including USB weirdness.
Reply 2 of 4, by sketchus
I haven't as of yet, I sadly don't have a PS/2 keyboard lying around. Caps haven't been changed but I will have a look.
Reply 3 of 4, by cyclone3d
First gen USB was notorious for causing latency problems. Never heard of it happening with a keyboard though.
Do you have the latest BIOS installed as well as the chipset drivers and newest USB drivers? Maybe use NUSB for the USB drivers.
I would definitely recommend using a PS/2 keyboard though.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 4, by sketchus
Newest drivers installed on the bios yep. I tried a third keyboard and that seems to have sorted it. Not sure what could possibly have been the problem that two keyboards don't work and a third did, since they were all USB.
