First post, by infiniteclouds
I'm using a SB Pro 2.0 and an AWE 64 Gold on a DOS/Win9x machine. I planned to mostly use the AWE64 for a joystick, SC-55, maybe audio for Windows games and the SBPro2 for digital audio/FM synth in DOS
I believe this is called an MPC-2 connector? The SB connector is called a "JST PH 2.0"?
My SB Pro 2.0 came with a cable that splits off to 4 different connectors on the opposite end... none of them are MPC-2.
If I want to connect the SBPro2 to the CD Audio would this cable do the trick- http://www.ebay.com/itm/MPC-2-w-clip-to-Sound … zAAAOxyVLNSxz8k ?
The AWE64 looks to have 2 CD IN ports including an MPC-2. Should I just get an MPC-2 <-> MPC-2 cable and use that? I'm thinking that any game that's going to use CD Audio isn't going to require use MIDI or FM -- or is that wrong? If not, I could just use the AWE64 solo for those games.
