First post, by luisile
Hi guys
Today i have managed to get tis mobo gigabyte ga-bx2000. after testing all work ok. So i updated the bios from stock v1,5 to latest from official site v.f9 with included app.but after restart the system work normal no issue except beep code after post. Its a sweep beep like firemans car high tone low tone a so on. what this mean? thanks for answer
Reply 2 of 5, by luisile
OK Solved the test power supply does not have the -5volt rail and bios repoted it as -69volt. changet to older power supply and everything is now OK.
Reply 3 of 5, by sketchus
That sounds like a CPU error. Check if the voltages are correct in the bios. If not, does that board have a secondary bios you can load?
EDIT: good to see you fixed it!
Reply 4 of 5, by Maxx1234
You may also use BIOS version F1 (ftp://78.46.141.148/mirrors/www.elhvb.com_mob … s/bx2000_f1.zip) - it seems to solve the problem.
