which is better?
First post, by weldum
hi, i have three processors but i do not know which is better.
the processors are these:
AMD ATHLON XP 2400+ 2000 MHZ THOROUGHBRED SOCKET A
AMD SEMPRON 2600+ 1600 MHZ PALERMO SOCKET 754
INTEL PENTIUM 4 2266 MHZ NORTHWOOD SOCKET 478
which one is the best? and the worst?
if it helps, these are the motherboards:
SOCKET A: FOXCONN/WINFAST K7S741GXMG-6L
SOCKET 754: BIOSTAR K8M800-M7A
SOCKET 478: ASROCK P4VM800
thanks
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 1 of 10, by Skyscraper
They are very close in performance all three.
It's very hard to say which one of them will perform the best, I think it will vary depending on the game / benchmark.
I would go with the Socket 754 system if building an Windows 2000 / Windows XP system. It's probably the slowest in most tasks but you can upgrade it to an Athlon 64 3200+, 3500+ or 3700+ later if needed.
Reply 2 of 10, by weldum
ohh right. in some benchs both the sempron and athlon performed a lot better than the pentium 4, and the sempron was a little better in memory benchs against the athlon, possibly due to hypertransport?
chances are that i never be able to upgrade these machines, either money problems or hard to find at a good price here in Argentina. so i will be using the sempron with a x1650, the athlon with a 9200se and the p4 with a mx4000
none of these are good or retro videocards, but i don't care because the use for these computers is mostly as test machines for various software/games and pc components
thanks Skyscraper
Reply 3 of 10, by Skyscraper
weldum wrote:
ohh right. in some benchs both the sempron and athlon performed a lot better than the pentium 4, and the sempron was a little be […]
thanks Skyscraper
The Socket 754 Sempron has a built in memory controller.
All three systems use single channel DDR memory.
Reply 4 of 10, by gdjacobs
thanks Skyscraper
The Sempron should also be capable of being underclocked for any speed sensitive Win98 games.
Reply 5 of 10, by melbar
Here are some benchmarks of an AMD Sempron 3100+ and your Athon XP 2400+, so you can compare them directly.
Remember that the Sempron 3100+ has 200 Mhz more and double the L2 cache compared to your Sempron.
http://www.anandtech.com/show/1409
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 6 of 10, by weldum
ooh, didn't know that
don't know about that, the bios in the mobo that i'm using is very limited, very few options for overclock/underclock, also, that computer is going to have XP, for 9x/DOS games I have various older pc's
i see, so both the athlon and the sempron are very close in benchs, because the sempron there is a little bit faster than mine.
Thanks guys
Reply 7 of 10, by gdjacobs
This can potentially be done via the MSR registers without menu options in the BIOS screen.
http://www.silentpcreview.com/forums/viewtopic.php?t=20872
Reply 8 of 10, by weldum
thanks, didn't know about that method
Reply 9 of 10, by leileilol
If it's a Sempron64, then overclocking the Sempron 😀
note that Sempron64s have SSE2 so it puts it an edge over AthlonXP there. OC'd Sempron64 systems were an underrated upgrade path in the day
Reply 10 of 10, by weldum
Could be, I have to figure out how to overclock on that limited bios, I'm used to more complete motherboards where the bios setup is better and more customizable.
