First post, by SaxxonPike
Hey all.
I was having a look at the VGA compatibility matrix and decided that I would snag an S3 Trio64V2/DX for super cheap. It's been a wonderful card so far, but it has exhibited some palette issues with One Must Fall. Sometimes the colors of the robots will bleed out into the arena colors. I haven't experienced this with any other game, nor any other video adapter I've used. Is there something I should try with this card specifically?
I'm also wondering if anyone else has had a similar issue with a different card, in case there might be more information we could have added to the VGA compatibility matrix to test.
This problem takes time to reproduce, unfortunately, and involves playing a few matches and watching the colors do weird things during the match.
Edit: Come to think of it, I have not found out which version of the BIOS exists on this card. I'll do that and update.
Sound device guides:
Sound Blaster
Aztech
OPL3-SA
Reply 1 of 1, by CkRtech
Isn't there some sort of setting for odd palette functionality/features in OMF2097? It seems like I turned one particular item off and did some other SVGA compatibility option when I played through it last year on a Virge DX. Seems like I had a snow issue of some sort.
Also - that compatibility matrix needs some work. Focuses way too much on odd obscurities and not enough on common games.
