First post, by maxdata63
Hello,
I recently fix an old 486 by changing it graphic card and hard drive. For this i bought this graphic card :
Vlb carte graphique spea v7 Mirage p32 s3 805 chipset 1 mo
After a memory upgrade from 4 Mo to 8 Mo i installed Windows 95 but i'm block in 640*480 16 colours
I tried Windows 95 RTM, OSR1 , OSR2.5 and i have the same problem of size and colour.
I found some drivers in your forum which i tried instead of Windows 95 S3 driver's but the problem is still here.
Can someone help me to find a solution ?
Thanks.
Specification of the system :
- Intel 80486 DX2 66 MHz
- 8*1 Mo EDO 30 pins
- Conner ~340 MB HDD
-spea v7 Mirage p32 s3 805
- Actually Windows 95 OSR 1.0
Reply 1 of 3, by weldum
how did you install the drivers?
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 2 of 3, by elianda
Win95 has the drivers included for the old S3 805 chipset.
As the card is VLB you have to detect it through the non-PnP hardware detection phase. (If you do not choose manually from the list).
Youtube Channel
Reply 3 of 3, by Jo22
I have to check, but I remember some early S3 chip was conflicting with serial ports.
It belonged to the S3 Vision series, I believe.
