First post, by David1010679088
Im running win2000 but when i open winnt/system32/command.com dosbox my keyboard wont type or what would appear, the display does not allow me to see what im typing. also i am using vdmsound and still when i try to configure my game for sound it crashes the program. how or what can i do to fix my keyboard not working and my game crashing? (im trying to run witch haven). thanks ...........
Reply 1 of 2, by vladr
Any difference when you run CMD.EXE as opposed to COMMAND.COM (from the "Start" menu, "Run...")?
Also, it's going to be tough to do this without a functional command prompt, but can you check your SYSTEM32 directory for the following files? (ignore win32k.sys)
C:\WINNT\system32>dir /od *.sys
Volume in drive C is System Win2K
Volume Serial Number is F43C-7187
Directory of C:\WINNT\system32
07/12/1999 08:00 29'146 ntdos804.sys
07/12/1999 08:00 9'029 ansi.sys
07/12/1999 08:00 4'768 himem.sys
07/12/1999 08:00 42'793 key01.sys
07/12/1999 08:00 42'521 keyboard.sys
07/12/1999 08:00 34'528 ntio404.sys
07/12/1999 08:00 29'146 ntdos404.sys
07/12/1999 08:00 29'370 ntdos411.sys
07/12/1999 08:00 29'274 ntdos412.sys
07/12/1999 08:00 35'392 ntio412.sys
07/12/1999 08:00 33'808 ntio.sys
07/12/1999 08:00 35'632 ntio411.sys
07/12/1999 08:00 34'528 ntio804.sys
17/12/1999 01:00 6'752 PfModNT.sys
04/05/2001 12:05 27'097 country.sys
04/05/2001 12:05 187'024 spcmdcon.sys
04/05/2001 12:05 27'866 NTDOS.SYS
30/10/2001 08:57 1'730'160 WIN32K.SYS
18 File(s) 2'368'834 bytes
CMD.EXE should really work, though, so try the DIR in there.
V.
Reply 2 of 2, by Snover
Remind me please, Vlad, how he's supposed to get a DIR listing if he can't view his command prompts? 😉
Okay, guy. I'm thinking there's a really simple fix for this one.
Run CMD instead of COMMAND. (COMMAND is a W9x remnant, CMD is NT's superior replacement.) Single-click on the icon in the upper-left corner of the window and choose "Properties". Go to the "Font" tab and choose your font to be first "Raster Fonts", then "Lucida Console". If that doesn't fix the problem, then try going into the "Colours" tab and ensure that your colours are the following:
[a note before I start: The information I list below is basically just ANSI colour data. The first number is the number of the colour box, 0-15 (there should be 16 of these lined up mid-window), the second is the value for RED, the third is the value for GREEN, and the last is the value for BLUE. Hopefully this isn't too confusing, but I have to squint to keep my eyes open at the moment, so suffice it to say my English might not be completely together at the moment.]
0,0,0,0
1,0,0,128
2,0,128,0
3,0,128,128
4,128,0,0
5,128,0,128
6,128,128,0
7,192,192,192
8,128,128,128
9,0,0,255
10,0,255,0
11,0,255,255
12,255,0,0
13,255,0,255
14,255,255,0
15,255,255,255
Then, select the first radio box, "Screen Text" and set this to the lighter grey (index #7). Select the second radio box, "Screen Background" and set this to black (index #0). You can do whatever with the popup colours, and of course, feel free to customise the colours to whatever you want them to be -- this is just the default.
Bah, I've said too much. Sorry.
Yes, it’s my fault.
