First post, by m5215tx
I have MS-DOS 6.22/Win 3.11 for Workgroups along with a Logitech 3 button serial mouse and the CuteMouse v1.9 driver. The mouse works great in DOS but fails to work in Windows. Any ideas why?
Roland MT-32 (old), CM-32LN, SC-55, SC-88VL, MT-120, SD-35, SD-20, SD-80, SD-90
Yamaha TG100, TG300, MDF2, MU15, MU100, MU2000EX + PLG150-DR + PLG150-PF + PLG150-VL
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
Reply 1 of 8, by derSammler
Yes, you need to install a mouse driver for Windows (using setup.exe). A DOS mouse driver is not going to work in Windows.
Reply 2 of 8, by m5215tx
So would this be a second mouse driver just for Windows or should I remove the DOS driver and then install the Windows driver for support in both Windows and DOS?
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
Reply 3 of 8, by derSammler
The Windows mouse driver is completely independent and used for Windows only. You need both.
Reply 4 of 8, by m5215tx
Ah, OK. Well, I will have to look into getting that setup and working. Thanks!
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
Reply 5 of 8, by Jo22
You can enable seamless mouse support in Windows 3.1 DOS boxes,
if you are also loading the original MS-Mouse (Version 8.?? ) driver for DOS at the outset.
Also, I recall that there was an issue with the latest version of CuteMouse.
For serial mice, an older version might be a better choice.
But I'm speaking under correction here.
Could well be possible that my information is oudated by now.. 😅
Anyway, using a serial mouse for Windows 3.1 is a wise choice.
In stark contrast to PS/2 mice. They behave "jumpy" or jerky in Windows 3.1.
Has something to do with lost packets..
(By the way, here's a good DOS driver that helped
me a few times with troublesome mice.. ^^)
Reply 6 of 8, by 80486DX2
Are you sure about it? I'm using Microsoft Mouse Driver 8.20 and it works well under both DOS and Windows 3.11.
Reply 7 of 8, by Jo22
True, MS-Mouse driver 8.2 (DOS) is compatible with both DOS and Windows 3.x DOS boxes.
But I assume he meant that Windows 3.x requires a separate Windows mouse driver also (mouse.drv in system.ini).
The original MS-Mouse floppy disks contained both of them (DOS/Windows), I believe.
Reply 8 of 8, by 80486DX2
That's right. I have an original Microsoft Mouse disk and there are both files on it:
- mouse.com
- mouse.drv
And it also contains a mouse.sys file.
