First post, by bluejeans
Maybe it has a dx that's just using an sx case?
Reply 1 of 4, by keropi
maybe it's a K6-III installed in an old case 🤣
there is no way to tell what's inside mate...
Reply 2 of 4, by brassicGamer
Maybe, but unlikely. While the DX was socketed and could technically be replaced (with a very limited number of options), the SX was not. So if the motherboard is original, it will be an SX. If that's all you're going on though, it could be a 486 or Pentium motherboard in that case!
Reply 3 of 4, by bluejeans
Or a z97 mobo with atx-at power supply adapter and the motherboard sticky taped down 😜
Reply 4 of 4, by Anonymous Coward
I would guess that if the motherboard has been replaced, it's probably just a 486...otherwise there would probably be a CD-ROM drive installed.
