First post, by LHN91
Hi all,
I've recently obtained a Compaq DeskPro EN P450, which has an onboard ESS 1869 audio setup.
I've set up Windows 98SE, added Phil's "Super Easy" DOS mode setup and then added ESS 1869 specific configuration details to the AUTOEXEC using the package at vogonsdrivers as a base.
SO far I've had luck getting the SoundBlaster portion working in DOS, but not the FM Synth. I've run DXDiag in Windows, and selected the ESS FM synth as midi device and that worked successfully, so I believe the hardware is present, but I've yet to get anything in DOS to use the FM Synth - although I've only tried Apogee games so far, it's what I had on hand.
Any suggestions as to what to take a look at? I do want to note I've been relying on the onboard speaker for sound, which seems to work for everything else.
