steering wheel support
First post, by guest
Hi I just installed vdm sound for the first time after doind a search on the net to see if I could get SBi6 dos games to work with my pci sound blaster live value
card. The sound is excellent,
but
When trying to tell the program what joystick I have it only gives me two choices
The button for "other" is greyed out and I need a way to indicate that I am using a steering wheel (thrustmaster grand prix 1). with right and left controlled by the wheel, forward and reverse controlled by hand paddles just behind the wheel and 4 buttons .
How do I set it up?
The available choice for "pair of 2 axis 2 button joysticks" recognises the wheel but I can only turn left and only go forward.
The system is as follows:
Intel d815 mobo p3 733mhz 128 mb pc133 ram
o/s = Win XP pro
using pci sb live! value card with xp drivers installed
The game in question is "need for speed"
As I said before the sound is perfect and the wheel is recognised ( which I had neither sound or joystick with this game before installing vdm),
I just need to know how to make it work with my wheel
If you can tell me how to configure it, that would be great
Thanks in Advance!
Paul
