First post, by bluejeans
Going to replace edo ram with sdram in this system but I'm confused about what they mean when saying (1)4mx64 and 2mx64 - at the very bottom it implies that I put 2 64mb sticks in bank 2 and 3, but the total ram is still only going to be 64mb?
Reply 1 of 7, by melbar
Here an example, that you can understand.
I'll take as example: Size 16MB , Bank 2: (1) 2Mx64
8 Bit = 1 Byte
(I'll take the decimal values, not the binary values...)
16Mb = 16MegaByte = 16.000.000 Byte = 128.000.000 Bit
2M x 8Byte = 2.000.000 x 8Byte = 2.000.000 x 64Bit = 2Mx64 = 128.000.000 Bit
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 2 of 7, by lazibayer
64 means 64bit-wide SDRAM modules, and (1) means 1-rank SDRAM modules. 1 x 4M x 64 (bit) = 256Mbit = 32MByte.
Reply 3 of 7, by bluejeans
melbar wrote:
Here an example, that you can understand. […]
8 Bit = 1 Byte
That makes sense. Any idea what capacity ram this is? It has the most chips of any edo/fast page I own, the numbers on the chips are fairly random and not indicative of a certain size (they're odd numbered for a start)
Reply 4 of 7, by devius
Define "this"... (or post a picture)
Reply 5 of 7, by bluejeans
Reply 6 of 7, by devius
That's not very helpful since the markings on the chips are unreadable. In any case if it has chips on the other side it's probably 8MB, if not probably 4MB. Best/fastest way to tell for sure is to stick it inside a computer and see how much it reports 😉
Reply 7 of 7, by Tetrium
bluejeans wrote:
That's EDO or FPM, it isn't SDRAM as those never came in SIMMs (this is a 72p SIMM).
Btw, the module is either 4MB or 8MB (8MB if it also has 8 chips on the other side of the module).
Agreed 😀
I liked using a PA-2005 or PA-2002 for this purpose, as it's a Pentium board that can read single SIMMs (it doesn't need pairs) and most 486 boards are either too rare to use as test bait or don't support EDO.
My retro rigs (old topic)
Report spammers here!
