First post, by Jiri
I get this curious error message during playing Overseer - DVD version when I switch locations. Not many problems with it yet - when I click OK, the game normally continues. So I posted it here mainly for fun.
Reply 1 of 15, by Snover
Jiri, you have a hardware DVD decoder or the thing manages to work with your software DVD decoder?
Yes, it’s my fault.
Reply 2 of 15, by Jiri
I have Mediamatics DVD Express - software decoder. Patch 1.04 for Overseer is installed and Windows 98 compatibility mode in Windows XP is enabled. The graphic card is GeForce FX 5200.
Reply 3 of 15, by Jiri
Seems that the problem has been solved. There is a VR Renderer in advanced preferences and "software" should be checked instead of "hardware" I had there. You have pointed in the right direction, thanks.
Reply 4 of 15, by Snover
heh, funny, I was just wondering because I remember Overseer refusing to work if you didn't have a hardware DVD decoder... 😜
Yes, it’s my fault.
Reply 5 of 15, by Jiri
So it was coincidence, but thanks anyway. 😉 Mediamatics DVD Express is solution for those who don´t have a hardware DVD decoder. I found an info about DVD Express on The Unofficial Tex Murphy Web Site www.unofficialtexmurphy.com. The game works fine with it so far in XP and I will have it completed soon.
Reply 6 of 15, by Lukas111
I have probably same problem and unofficial web doesn´t work...I have same problem that I have not a hardware mpeg-2 encoder...I installed the game on Win 98 but it never shows animations or there is a message that it can´t inicialize MPEG-2 encoder...can U help me....please...........
Reply 7 of 15, by Lukas111
I read that only way to solve my problem may be a DVD Express but i can´t find it to download do you have it or do you know where is possible to download it???? Help me please
Reply 8 of 15, by eL_PuSHeR
How many times are you going to post about the same thing? I am pretty sure i have read on another "overseer" thread changing some advanced settings to "software rendering". Did you try that?
Reply 9 of 15, by Lukas111
I am sorry...I just trying...I don´t want to spam you...
Reply 10 of 15, by eL_PuSHeR
It's okay...
Reply 12 of 15, by Lukas111
For anyone who had same problems like me...Mediamatic stops support of DVD Express. Only one place I found...where is possible to download this ugly SW...there is a link : http://www.unibw-muenchen.de/campus/RZ/RZN/AS … yerWindows.html
And if you want LAST update check the IBM site. There is 5.2 version...
http://www-307.ibm.com/pc/support/site.wss/do … cid=MIGR-4GV37K
and for compatibility problems with setup in Win2K :
install SP3 or SP4 and then in "Start-Run" type : resvr32 %SystemRoot%/apppatch/slayerui.dll after that - there will be possibility to set comaptibility for WIN9x in Properties menu when you are making a shortcut...
And one last think....thanx to all fans wich helped me and special to GregG from unofficialtexmurphy.com message board...
Now bye...Tex is waiting... 😊
Reply 13 of 15, by Lukas111
It seems that I have no luck...the link for DVDExpress is functional, but software itself not!!!! So still looking...IS THERE ANYBODY WHO CAN MAIL ME THIS SW?
Reply 14 of 15, by Jiri
I installed the game on another computer (DVD version in XP) and Mediamatics DVD Express also did not work correctly there. Then I found out that the game should work also with Elecard MPEG2 player v.1.35 and it helped. Besides - it is much smaller download (approx. 1MB instead of 20MB) and not so hard to find on the net as Express, a copy is for example here. (I do not know if the game works also with the newer versions of Elecard).
In order to get the game working with Elecard, the patch 1.04 must be installed and Xing MPEG2 should be selected in MPEG2 device at the configuration screen.
I had also problems with stuttering sound, but it ceased when I disabled sound hardware acceleration on dxdiag. Bad responses of the keyboard I had were solved by enabling Win 98 compatibility mode on the game exe.
Reply 15 of 15, by Qbix
Rank DOSBox Author
DOSBox Author
I think all the needed info is in here and some people don't know that colors and bold are evil.
Closing this thread. Thank you for your answer jiri.
Water flows down the stream
