First post, by keropi
- l33t++
Hiya!
I started using an EGA/VGA combo card in my 286/EGA setup and Supaplex detects it as a VGA card even though the card is jumpered as an "EGA PURE" one (and working with a true EGA monitor) . So in the Supaplex SpeedFix documentation there is info on how to force EGA mode in the original non-patched game:
+------------------------------------------------------------+| HOW TO FORCE THE EGA MODE WITH THE ORIGINAL SUPAPLEX CODE: |+------------------------------------------------------------+With one additional line, the above batch job can also force the video modeon VGA cards to run as if it runs with an EGA card, and with debug mode on.The behavior and the colors of Supaplex are totally different now.Different code is used in the program, and the standard 16 colors are used instead of using the VGA palettes for nicer colors.@echo offecho g33 > supaplex.debecho t >> supaplex.debecho g103 >> supaplex.debecho t >> supaplex.debecho ecs:5378 0 >> supaplex.debecho ecs:a040 1 >> supaplex.debecho g >> supaplex.debecho q >> supaplex.debdebug supaplex.exe < supaplex.debdel supaplex.debJune 15, 2007 SPFIX63a.DOC Page 32 of 50The EGA mode is switched on with the line: echo ecs:5378 0 >> supaplex.debThe debug mode is switched on with the line: echo ecs:a040 1 >> supaplex.debThe lines with g33,t,g103,t are to persuade Supaplex to unpack itself.Supaplex has to be unpacked, since the debug byte is inside of a packed block.
I tested with the "ecs:5378 0'" option only since I have no interest in the debug mode and it works fine. I unpacked the EXE with UNP but how do you translate the "ecs:5378 0" command? I looked some debug help online and it appears this is a search-and-replace function in a ram location but that's as far as I went š¤£
Any tips on how to proceed? š TIA!
šµ š§ ā³ ā” SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and š¶GoldLib soundcard website
š¾š¾š¾ Looking for a full version of LIST ENHANCED 2.4y1 by V. Buerg, message me if you have it for sale! š¾š¾š¾
