Reply 400 of 1192, by feipoa
- l33t++
Did you read above? I was thinking about 10, 100, 200 nF here. But no feedback. Tantalums of size 2312 do not come in these capacitance values. Smallest tantalum in 2312 is 470 nF.
We might be able to use 1210 ceramics (3.3x2.5 mm) but the centre section is around 2.1 mm and the PCB gap is 2.85 mm. I can hover the caps a bit to not touch the centre gap, but the overhang of the metal contact would only be 225 um thick on each side.
This is what I'll be ordering for caps. I think it should cover any changes I might make after testing and any recommendations which may come in from viewers later on.
Tantalum 2312 6.0 mm x 3.2 mm
0.47 uF
10 uF
22 uF
47 uF
100 uF
Tantalum 1411 3.50 mm x 2.80 mm
150 nF
220 nF
330 nF
Ceramic 1210 3.30 x 2.50 mm
10 nF
47 nF
100 nF
220 nF
Price of caps have really gone up.
