S3 Trio3D/2X VESA TSR?
First post, by keropi
Hiya!
I am using an S3 Trio3D/2X with my ss7 machine and I noticed that I cannot get 320x400 resolution to work in Duke Nukem 3D. Although the card has a VBE2.0 BIOS it appears that it's "missing" some stuff 🤣
UNIVBE 6.7 or S3VBE20 do not support the Trio3D/2x chipset, maybe someone knows of a TSR that works?
TIA!
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 1 of 4, by wbc
guess what 🤣
by the way, I've noticed "snow" artifacts in Duke3D on Trio3D/2X during palette change (with or without S3VBEFIX in every VESA or VGA mode), seems that someone can't wait until retrace to update palette without glitches 😀
--wbcbz7
Reply 3 of 4, by dirkmirk
320X400 is a good mode in Duke Nukem 3D on my cyrix 5x86-120 with ark logic VGA, the performance hit is small from 320X200 and is a noticeable improvement in visual quality.
Reply 4 of 4, by wbc
you can also try 320x480, 400x300 and 512x384 via tweaking resolution parameters in DUKE3D.CFG, but butmap gfx (such as HUD, title\endlevel screens etc.) will be stretched.
--wbcbz7
