First post, by Deksor
I've recently acquired a Diamond Edge Card 3240 that seem to work. Unfortunately, I only have the card. I wondered if I couldn't re-create the game port that goes through an ethernet-like connector using an old network cable and a midi port. All I'd need then is a pinout. Is there somebody here that has this card in it's possession that could make the pinout for me ?
Tanks in advance !
Reply 1 of 1, by Jepael
Network cables have 8p8c connectors, it looks like you need 10p10c connector.
I don't know if it has MIDI pins, as for two standard joysticks or one special joystick you need all 10 pins (4 pots, 4 buttons, supply and ground).
