First post, by Zoomer
- Member
Hey, I'm trying to build a k6-3+ based time machine to conserve space. Mostly I'm following Phil's YouTube guide.
So the problem is I get lock up (full freeze) 2-3 minutes after windows 98se gui loaded.
I have a gigabyte GA5-AA (ali 5) motherboard. I've tried several different videocards, memory sticks, bus/multiplier settings, different harddrives, bios settings, Win98 installations, etc. The result is always the same. It happens with or with any drivers installed. Tried pulling out all cards and disabling onboard features.
The only thing that helps is changing CPU to Pentium MMX 233. Then everything works great.
The funny thing is that K6 works without any problems until W98 start. I can even do a format/full w98 install with it, but only till tge first gui start.
My cpu is K6-III+ 450ACR 2.0v. Somehow it's detected as K6-III 333 and runs at 333mhz at 2v/x6 multiplier. Is there some sort of incompatibility with motherboard? Is it because it's "embedded" version? Or is there something that I miss? My motherboard runs latest f7b bios.
MB: Asus P3B-F 1.03 (2x ISA)
CPU: PIII-S 1.4GHz/VIA C3 800MHz
RAM: 256MB PC133
Video: GeForce 4600Ti/Voodoo 5 5500/Voodoo 3 3500 for DOS Glide
Audio: SB16 OPL3 + Audigy Platinum Ex
OS: Windows 98
