First post, by Pingaloka
Hi guys, tomorrow IK'm going to buy a CRT monitor.
I already have a 14'" one but I would like get a bigger one.
I'm going to connect it to my Pentium computer to play MS-DOs games (no windows)
So, I have to options. What I'm worried is that there could be resolution issues with the
first monitor and 320x240 games? Is it too big to play Ms-DOS games, will I see huge pixels!!?? Not that I mind 😀
a) Philips 109B60 - CRT monitor - 19"
SPECS:
Display Type CRT monitor / CRT
CRT Type Real Flat
Native Resolution 1920 x 1440 at 64 Hz
Controls & Adjustments Brightness, contrast, H/V position
Dimensions (WxDxH) 17.3 in x 17.7 in x 17 in
OSD Languages Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Korean
Color Temperature 9300K, 6500K, 5500K
Viewable Size 18"
Pixel Pitch 0.21 mm
Screen Coating Anti-glare, anti-reflective, anti-static, high contrast coating
Horizontal Refresh Rate 97 kHz
Video Bandwidth 250 MHz
Vertical Refresh Rate 160 Hz
ManufacturerPhilips
POWER DEVICE
Power Consumption Operational 70 Watt
POWER
Power Consumption Stand by / Sleep 1 Watt
Power Supply internal
INTERFACE PROVIDED
Qty 1
Connector Type 15 pin D-Sub (DB-15)
MISCELLANEOUS
OSD Languages Chinese (simplified), English, French, German, Italian, Korean, Portuguese, Spanish
Controls & Adjustments H/V position, brightness, contrast
Color mist white
DISPLAY
Type CRT monitor
ENVIRONMENTAL STANDARDS
ENERGY STAR Certified Yes
SYSTEM REQUIREMENTS
OS Required Microsoft Windows 98SE/2000/ME/XP
MECHANICAL
Display Position Adjustments Swivel, tilt
DIMENSIONS & WEIGHT
Width 17.3 in
Depth 17.7 in
Height 17 in
Weight 44.09 lbs
ENVIRONMENTAL PARAMETERS
Min Operating Temperature 32 °F
Max Operating Temperature 95 °F
HEADER
Brand Philips
Product Line Philips
Model 109B60
Packaged Quantity 1
Compatibility PC
PROJECTOR
Max V-Sync Rate 160 Hz
Max H-Sync Rate 97 Hz
CABLE DETAILS
Type VGA cable
Included Qty 1
TV TUNER
TV Tuner Presence No
GENERAL
ManufacturerPhilips
b) Hyundai ImageQuest Q770 - CRT monitor - 17"
35211730414_aa6b5e4c72_o.jpg%22
CRT Type DynaFlatX - shadow mask
Native Resolution 1280 x 1024 at 60 Hz
Factory Preset Resolution Modes 720 x 400 / 70 Hz
640 x 480 / 100 Hz
800 x 600 / 85 Hz
1024 x 768 / 75 Hz
1024 x 768 / 85 Hz
1152 x 864 / 75 Hz
1280 x 1024 / 60 Hz
640 x 480 / 66.7 Hz
832 x 624 / 75 Hz
1152 x 870 / 75 Hz
Controls & Adjustments Brightness, contrast, H/V moire, H/V position, H/V size, rotation, trapezoid, degauss, color temperature, parallelogram, pincushion, bottom corners, top corners, pin balance, V linearity, H Linearity
Dimensions (WxDxH) 15 in x 16.2 in x 14.6 in
Viewable Size 16"
Pixel Pitch 0.2 mm
Horizontal Refresh Rate 70 kHz
Video Bandwidth 108 MHz
Vertical Refresh Rate 150 Hz
ManufacturerHyundai
POWER DEVICE
Type power supply
Nominal Voltage AC 120/230 V
Frequency Required 50/60 Hz
POWER
Power Consumption Stand by / Sleep 5 Watt
INTERFACE PROVIDED
Qty 1
Connector Type 15 pin HD D-Sub (HD-15)
MISCELLANEOUS
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, GOST, cUL, DDC-1, DDC-2B, DHHS, EN55022, NUTEK, PCBC, SEMKO, TCO '99, VCCI-I, VESA DPMS
Controls & Adjustments H Linearity, H/V moire, parallelogram, pin balance, pincushion, rotation, top corners, trapezoid, H/V position, H/V size, V linearity, bottom corners, brightness, color temperature, contrast, degauss
Color silver
MTBF 50000 hour(s)
DISPLAY
Type CRT monitor
SOFTWARE / SYSTEM REQUIREMENTS
Included Software Drivers & Utilities
DIMENSIONS & WEIGHT
Width 15 in
Depth 16.2 in
Height 14.6 in
Weight 34.17 lbs
Max Altitude Operating 9840 ft
Humidity Range Operating 35 - 80%
HEADER
Brand Hyundai
Product Line Hyundai ImageQuest
Model Q770
Packaged Quantity 1
Compatibility Mac, PC
PROJECTOR
Max V-Sync Rate 150 Hz
Max H-Sync Rate 70 Hz
CABLE DETAILS
Type display cable
Included Qty 1
Length 6 ft
SOFTWARE
Type Drivers & Utilities
TV TUNER
GENERAL
ManufacturerHyundai
Reply 1 of 4, by olddos25
Try them both and see which one you like the most.
Just another user that likes old OSes and videogames, nothing interesting to see here...
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
Emaculation: https://www.emaculation.com/forum (as macplus)
Reply 2 of 4, by Pingaloka
Yeah, I was worried about any incompatibility issues. I'll tell the guy to show them
on if possible and decide which one looks better. 😉
Reply 3 of 4, by RetroGamingNovice
I'd personally recommend either a Sony monitor or any monitor with a Sony tube in it if going CRT, Trinitrons were about the best CRT you could get.
PC hardware: Ryzen 5 4500, 32GB RAM, 1TB SN 570 /500GB 970 EVO Plus/2TB 970 EVO Plus/1TB 870 EVO,, RX 6600 GPU, Arch Linux/Win10 dual-boot
Reply 4 of 4, by subhuman@xgtx
Take into consideration that many of the trinitrons are pretty worn out at this point in time, whereas shadow mask seem to last a few years more?
It's a matter of trying and choosing the one in better condition 😀
Bear in mind I usually post to the forums using my old systems.
