First post, by DMJC
Hi Guys,
I'm experimenting with some games on FreeDOS as part of a project. I was wondering if anyone has gotten Wing Commander: Privateer to run in FreeDOS and if they could share their EMS/XMS settings with me? Privateer uses a very weird JEMM layer to provide expanded memory. Dosbox has correctly implemented it, but I am looking at an alternative to Dosbox due to performance issues. (mainly that even on an i7 Kabylake, Privateer will slow down in moments where a 486 did not used to slow down.)
Reply 1 of 3, by gdjacobs
þ The JEMM ;-) DOS Extender (used for "Strike Commander" and "Privateer") requires the NOVME option to be set. This requireme […]
þ The JEMM 😉 DOS Extender (used for "Strike Commander" and "Privateer")
requires the NOVME option to be set. This requirement is a strong sign
that this extender switches to V86 mode on its own, which is a bad idea
for a VCPI client.
From the JEMMEX/JEMM386 readme.
Reply 2 of 3, by Azarien
I remember Privateer having weird memory requirements even in DOS 6.22 times...
Reply 3 of 3, by DMJC
Well that didn't work at all. I suspect both KVM and DOSEMU don't support VCPI properly. setting the noVME option one way or another did not work.
