First post, by Private_Ops
Private_Ops
Offline
- Member
I have an old BCM SQ599/P54SB motherboard.
Two questions.
Can this board use an MMX CPU? If not, why?
Also, it has an SiS 6205 onboard chip but, did not come with a header cable. It has a 15 pin connector, should I be able to use a VGA header cable on this?
