Q3A crashing to desktop.
First post, by Jade Falcon
Rank BANNED
BANNED
I can't seem to get quake 3 to work on my 9x box.
When it start the game I get a grey screen and the have crashes to the desktop a few seconds later
No error or blue console window. The desktops screen Rez is set to 640x480 after the game crashes.
I installed the games opengl driver but no go.
System is
400mhz celly slot1
64mb ram
440lx broad
Sb16
98se (clean install aside from sp3)
G400max and voodoo1
Does the game have a console log or anything?
Any idea?
Reply 1 of 6, by Putas
The game should run with both of your cards, on the Voodoo only at 16 bit depth. Other OpenGL applications are working?
enable console logging 0=no log 1=buffered 2=continuous 3=append
Reply 2 of 6, by Jade Falcon
Rank BANNED
BANNED
Well the game will not even start, do I add that to the end of the EXE?
I don't know, I haven't tried any. Will do tonight.
Reply 3 of 6, by Jade Falcon
Rank BANNED
BANNED
Look like it's a OpenGL problem. Ut99 will not work in OpenGL ether
Reply 4 of 6, by Jade Falcon
Rank BANNED
BANNED
Installed the newest drivers for the g400max and the game crashes to the console with the fallowing error.
q_strncpyz: null src
Reply 5 of 6, by Jade Falcon
Rank BANNED
BANNED
Swapped out the g400 max for a gf3 and the game running, but at less then 1fps in the menu even.
Any advice?
Works fine on the voidoo1
Reply 6 of 6, by darry
Do you have any opengl32.dll files other than the Microsoft Windows one lying around in your system path or in the affected games' directories ? If you do, they are probably copies of the 3Dfx miniGL driver, which would explain why (only) the Voodoo works .
