First post, by Serious Callers Only
Is it just my impression, or does this game not have a quit key? I know it's a conversion from a booter machine, but are you supposed to just turn off your computer when you quit playing this? Lol.
Yes, IIRC FE2 doesn't have a way to exit the game.
(edit) just fired it up, yes it's as I recalled, the exit button just restarts the game. Time to reach for that reset button.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
No, it doesn't have a quit option. It is also very demanding of memory so you would usually have to boot the computer specially to run it anyway.
"AI Requires Proof That You Are Human"
wrote:No, it doesn't have a quit option. It is also very demanding of memory so you would usually have to boot the computer specially to run it anyway.
580kB conventional and 768kB expanded memory.
I/O, I/O,
I/O, I/O
wrote:...a booter machine...
Hahah. Somehow that reminds me of that highretrogamelord dude on youtube and his imperial craptonne of videos, whose descriptions go like "Clusterduck Pro II came out in 1987 for the PC Booter". One might get the impression that it was some unlicensed clone of the PC Engine or something.
It's quite possible that because of those conventional memory demands (and/or laziness) the programmers simply elected to stomp all over DOS, so that returning to it is no longer possible.
I may be wrong, but I remember Alt+X.
We're both wrong. It's actually CTRL+C, at least for the CD-ROM version. Strange, I was sure there was no quit option. Can someone check if this also works with the original floppy release?
