First post, by Kahenraz
I have this card which has headers for floppy, SCSI, and an external parallel port. It uses jumpers for configuration.
Will I need drivers for this or will it "just work" in AT and ATX motherboards?
I'm also unfamiliar with this BIOS Address Select jumper. What is it?
Reply 1 of 1, by Matth79
The BIOS address will be where it places the SCSI BIOS, so it should be bootable, and support DOS without drivers
