First post, by Andy1979
- Newbie
Today I received a "Soundblaster 16 Pro Value" ISA card, marked CT2910 on the board, but CT2911 on the sticker on the back of the board. It's a long, non-PNP board with an IDE interface. This has been installed in a P133 system, using an Intel 'Marl' motherboard (430HX chipset). I have set the jumpers and established that there are no IRQ/DMA conflicts (it's set up at IRQ10 and as the tertiary IDE controller).
I found the 'SBIDE' driver (version 2.05) on Vogons Drivers and have managed to get the CD drive to work in Windows 95, so I know that the card is working.
However, under my existing installation of Windows 98SE I cannot get the CD drive to show up. If I use the built-in Windows drivers (dated 1999) then the IDE interface is visible with the correct IRQ and DMA settings, but no drives are detected. If I use the Win95 drivers then I get an exclamation mark in device manager, stating that there is a problem with the device. Under both scenarios the drive isn't seen by MSCDEX when I exit into MS DOS mode. The NT4 installer also doesn't detect the CD drive.
Does anyone know of working CD interface drivers for this card under Windows 98SE / NT4?
Appreciate it would be easier just to use the on-board secondary IDE controller (which works) but I have other plans for that.
Apologies if this is already covered somewhere but I couldn't find the answer on the forum.
My Retro systems:
1. Pentium 200, 64mb EDO RAM, Matrox Millennium 2mb, 3DFX Voodoo 4mb, DOS6.22 / Win95 / Win98SE
2. Compaq Armada M700 laptop, PIII-450, Win98SE
3. Core2Duo E6600, ATI Radeon 4850, Win XP
