Masters of Magic
First post, by Lost Guest
I set the exe to run with max in the memory tab... if I run without VDMsound works okay...
if I right click and run with VDMsound it gives me the following error message
"Isufficient memory. You need at least 575k free. Try removing all TSR's"
any ideas?? (I have dosbox just dunno how to use with vdmsound)
Reply 1 of 1, by MiniMax
Rank Moderator
Moderator
Have you tried enabling XMS and EMS in VDMSound (Compatibility tab)?
DPMI? HIMEM.SYS? Allow DOS to use UMB?
DOSBox and VDMSound are two separate solutions to different problems. Have almost nothing to do with each other.
_________________
