First post, by Erik765
Perhaps I'm completely off my rocker but back in the day we had a Compaq Deskpro 386n that had no room to add a CD drive so my dad came home one day with a Sound Blaster and an External CD Rom drive (2x). I would have bet my life on the fact that it was a Creative Labs drive, and was sold as a bundle (like the Easy 16 (CT2750 or CT2759)), but I can't see that these were ever sold together and even more- I can't find any external Creative drives at all.
It did connect via parallel either way (into the SB itself).
If I recall correctly, the drive had indents (like lines) going from front to back on the top of it (as a design).
Am I wrong here and it was another brand of drive? Or is my Google-foo just broken?
Anyone have any clues?
Thanks.
Reply 1 of 12, by darry
AFAIK, the only external option with a Sound Blaster would have been with a Sound Blaster 16 SCSI, but that only had an internal SCSI connector and would have required running a 50-pin IDC cable from the inside of the PC into an adapter and finally into an external SCSI CDROM (I am not aware of any Creative branded ones).
Could you describe the cable and connector used in more detail ?
Reply 2 of 12, by cyclone3d
It might have been a Backpack CD-ROM drive bundle. There were a few different companies that bundled stuff together.
Did it look like the drive here?:
http://minuszerodegrees.net/backpack_cdrom/ba … kpack_cdrom.htm
Could have even been a store made bundle. Those used to be quite common back in the day.
Edit: If it was bundled with a Creative Sound Blaster 16 SCSI card, maybe it was a Texel DM-5024 drive as seen here:
https://books.google.com/books?id=v9TVJ_G_sk8 … dm-5024&f=false
Better picture on an ended eBay lsisting:
http://www.ebay.com/itm/Vintage-Texel-DM-5028 … =p2047675.l2557
Could have also been something else.. like maybe is was a PAS16 card bundle. A few options are listed here:
https://books.google.com/books?id=7k7q-wS0t00 … 0bundle&f=false
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 12, by Erik765
@Darry, it was a db25 connector (standard parallel style)
@cyclone3d, it definitely wasn't scsi or much wider than an internal drive and we only had 2 ISA slots- one was used for our modem and the other for the sound card. I suppose it could have been a backpack, yes. I just don't recall it saying Backpack on it anywhere and swear the disc tray said 'Creative' on the front of it... Hmm, perhaps it was a custom or store-made bundle. That's really the most likely, isn't it? Store-made bundle of a backpack with a Creative drive thrown in it for some reason. It was definitely 2x.
Reply 5 of 12, by darry
Wow Cloudschatze! First time I've heard of one of these . The drive bezel looks suspiciously like an OEM Matsushita CR-562/CR-563. Do you know if it is ?
Would this be the accompanying sound card/interface ?
https://reuseum.com/sound-blaster-easy-16-ct2 … -rom-interface/
Reply 6 of 12, by Unknown_K
I had (still do I think) and external enclosure for a CDROM drive) that connected to a connector on a slot cover (had a 4 pin molex plug for power) and a cable that went to your sound card or IDE forget which. It was pretty old.
Reply 7 of 12, by Cloudschatze
CR-563-C, to be exact.
Yes, indeed.
I'd meant to add this to the "Gallery of Strange Sound Devices" thread, but never got around to it. The SB Easy16/CD is an interesting, and surprisingly solid combination (with a few caveats), whereby the CD-ROM enclosure itself incorporates much of the analog stage and I/O connectivity of a standard SB16, similar in design to Media Vision's PAS16-based CDPC and Memphis solutions.
Reply 9 of 12, by chinny22
Doubt you will ever see one in real life again though 🙁
I'm keeping 1/2 eye out for the far more common internal Panasonic/MKE drive but most have long gone either from legitimately dying or incorrectly diagnosed as a non working IDE drive (IDE cable fits the connecter but that's where the similarity ends) and thrown out.
Reply 10 of 12, by Anonymous Coward
I've seen that Easy 16 card a few times, but this is the first time I've seen a picture of the external enclosure that goes with it. It's actually pretty neat.
I believe that Creative may have had an external option for the CT1770 as well, using a ribbon cable that leads to an HD50 connector on a ISA back plate.
Reply 11 of 12, by fitzpatr
http://www.ebay.com/itm/Sound-Blaster-Pro-SB- … =item1a3381de67
This eBay listing has the pictured card. Definitely an External CD Card.
    202.75 KiB
    CT-1810 Creative External CD ISA Card
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 12 of 12, by lolo799
I recall such a drive but it was a 1x with a caddy loading system.
The drive must have been the Panasonic CR-521, CR-523 or CR-531 according to https://web.archive.org/web/19961225081615/ht … pec/techcd.html, but in an external enclosure:
