Has anyone tried this combo?
2 of the above 440LX + Slocket with a socket 370 Celeron on a Shuttle brand board with great official BIOS support .
From what I've seen , the P2L97-DS seems to be more limited : https://www.asus.com/supportonly/P2L97-DS/HelpDesk_CPU/ .
According to https://translate.google.ca/translate?hl=en&s … 577&prev=search , with a recent (latest?) BIOS, Coppermine Pentium 3 based Celerons (and most likely Coppermine Pentium 3 CPUs too ) should at least POST . Cyrix CPUs, I do not know .
I did try a Slot 1 P3 (500 IIRC) in it but it wouldn't post. Not sure if it's incompatible or just a bad CPU.
If the BIOS is sufficiently updated, I would expect it to at least POST, as that is a Katmai core, which is older than Coppermine and Coppermine apparently works (see above).
I have a Cyrix III 700 (7x100) or a PIII/600 (6x100) that I could use. Are either of these chips likely to work with the 440LX mobo?
I have never tried, but if I had to guess I would say no (fairly uneducated guess). Additionally, the voltage requirements of these CPUs are likely incompatible with your board's VRM . Unless any of these can safely run at 2V (maybe 1.8V if this is accurate http://baber.com/baber/411/asusp2l97ds.htm ), you risk CPU damage
Also are there different types of slockets I have to watch out for, or are they all functionally the same?
Chronologically :
a) PPGA capable, the oldest type, that only supports first generation socket 370 CPUs . May or not have jumpers for FSB and VID voltage (to force the motherboard to supply a given voltage, if it is capable)
b)FC-PGA capable that supports Coppermine CPUs . May or not have jumpers for FSB and VID voltage (to force the motherboard to supply a given voltage, if it is capable)
c) FC-PGA2 capable that supports Tualatin CPUs . Usually has jumpers for FSB and VID voltage (to force the motherboard to supply a given voltage, if it is capable). At least one series from Powerleap has an onboard voltage regulator to allow bypassing the limits of the motherboard VRM .
Slocket types b) and c) will usually work with older CPU type through the use of jumpers or DIP switches . Generally, the motherboard BIOS must recognize at least the CPU family for the system to POST .
