First post, by tabm0de
I Have a 8086 computer which allowed http://th99.classic-computing.de/src/c/U-Z/20615.htm controller card to work in the 8-bit isa Slot even if it is a 16-bit card.
Problem is that gotek won't pass 360kb floppy size, is this a pc limit since the card does support 1.44mb?
naa, nothing yet...
Reply 1 of 5, by Deksor
The BIOS of XT computers is limited. Use a program called 2M-XBIOS to expand it's capabilities under DOS in order to read from floppies bigger than 360K ^^
You won't be able to boot from floppies formated as 1.44MB (or even 720k) but at least you'll be able to transfer files more efficiently
Reply 2 of 5, by tabm0de
Thanks ! 😀
naa, nothing yet...
Reply 3 of 5, by tabm0de
gotek dont seem to have 360kb version that i can find, so i am stuck on needing 5.25 floppys for booting or installning os 😒
naa, nothing yet...
Reply 4 of 5, by Deksor
If you used a real 1.44" floppy disk drive, you could write a 360K image onto a 720K floppy disk (I used to do this with my 8088 ^^)
I never used a gotek so I don't know how that works
Reply 5 of 5, by Errius
Stock IBM PC/XT works fine with 720 KB disks. Just look out for Amiga users dumping their old floppies on eBay.
Is this too much voodoo?
