AWE 32 emulation ?
First post, by guest
Hi to all,
One simple question: Does VDMSound emulate an SB AWE 32 ?
Sorry if this question is asked before. I did a forum-search but found no answer.
Thanx
Reply 1 of 4, by robertmo
No, it doesn't.
Is there any reason for AWE32 emulation for you?
Every game that have AWE32 support should also have General MIDI/ Sound Canvas/ SCC-1/ MPU-401 support which is actually the same.
Reply 2 of 4, by Reckless
Wouldn't the AWE32 have had better sound (if specifically driven) as it had the Wavetable device bolted on to it? I don't know anything technically about these things though...
Reply 4 of 4, by guest
Thanx for your reply. My old PC have an AWE 32 and the sound quality seems to be better than the emulated one on my new PC. The bad thing is, that this SB is an old ISA card, but my PC don't have a port for this. It seems i have to handle my old PC very well 😉
I didn't tested General MIDI. I'll give it a try.
Are there any adapters available to put a ISA-card into an PCI or AGP Port?
Thanx
