First post, by sd6
Looking for a little help with the 486 pc I've just built. It started out as an osborne 486 with a micronics board. The motherboard was dead and i replaced it with a board out of an ibm value point. It fits perfectly into the case, only part that doesn't work is the vlb riser card. Its a different pinout but i have one suitable for the ibm board on its way. I had the common 528mb hard drive limitation, its a 3gb Fujitsu that i partitioned as 528mb for the time being to get around the issue. Every time i turn the computer on it reports memory error and memory size error, going into the bios menu it reports the correct amount of memory installed. Once i enter the windows installation the first error i see is when loading DOS, i get a PCI READ CONFIGURATION FAILURE, after that things continue on as normal, i can format the drive and input the installation command. The installation begins and runs scandisk and passes. After this the installation hangs with the message "Not enough free extended/xms memory to run setup" I have no idea why the motherboard is rejecting the memory and it doesn't matter what order i install the sticks. I am unsure if it is the cause of the xms memory fault. I haven't touched hardware this old in 15 years and i was a little kid at the time so i'm not up to scratch.
Reply 1 of 6, by Andy1979
Welcome to the joys of DOS memory management. It's not the physical memory but how it's set up. All down to original PC XT having a 640K memory limit, so you have to tell the computer what to do with any memory above this to maintain DOS compatibility. Windows NT/2000/XP onwards don't have this problem. Have a look on the phils computer lab website and it should tell you how to set up your config.sys and autoexect.bat files to fix this error.
My Retro systems:
1. Pentium 200, 64mb EDO RAM, Matrox Millennium 2mb, 3DFX Voodoo 4mb, DOS6.22 / Win95 / Win98SE
2. Compaq Armada M700 laptop, PIII-450, Win98SE
3. Core2Duo E6600, ATI Radeon 4850, Win XP
Reply 2 of 6, by derSammler
What does "mem" say?
Make sure either HIMEM.SYS is loaded in config.sys or XMSMMGR.EXE executed via autoexec.bat or directly in the DOS shell.
Reply 3 of 6, by Imperious
You haven't mentioned what version of Windows You are installing, If not already I would only use Win95 on a 486.
Just load Himem.sys in your config.sys file and I reckon that should sort it out. It should look something like this.
DEVICE=C:\DOS\HIMEM.SYS
Load it first in the config.sys
Reply 4 of 6, by GPA
PCI READ CONFIGURATION FAILURE is most probably reported by scsi driver that tries to scan PCI for a card but there is no PCI in your system - that is totally fine. This happens when you boot from Windows 9x boot floppy.
The thing that's strange is the extended/expanded mem error however. Windows 9x boot floppy loads HIMEM.SYS that manages XMS, so this is a weird error.
Try editing CONFIG.SYS and adding /TESTMEM:ON /VERBOSE flags to HIMEM.SYS. It may explain you why it doesn't load.
Also, there is /MACHINE: flag for HIMEM that you may need to set po ps2 since you have IBM PS mobo:
/MACHINE:xxxx
Specifies what type of computer you are using. Usually, HIMEM can detect
your computer type successfully; however, there are a few computers that
HIMEM cannot detect. On such systems, HIMEM uses the default system type
(IBM AT or compatible). You might need to include the /MACHINE option if
your computer is a type that HIMEM cannot detect and if HIMEM does not
work properly on your system by using the default system type.
Currently, systems that require this option include Acer 1100, Wyse, and
IBM 7552.
The value for xxxx can be any of the codes or their equivalent numbers
listed in the following table.
Code Number Computer type
at 1 IBM AT or 100% compatible
ps2 2 IBM PS/2
ptlcascade 3 Phoenix Cascade BIOS
hpvectra 4 HP Vectra (A & A+)
att6300plus 5 AT&T 6300 Plus
acer1100 6 Acer 1100
toshiba 7 Toshiba 1600 & 1200XE
wyse 8 Wyse 12.5 Mhz 286
tulip 9 Tulip SX
zenith 10 Zenith ZBIOS
at1 11 IBM PC/AT (alternative delay)
at2 12 IBM PC/AT (alternative delay)
css 12 CSS Labs
at3 13 IBM PC/AT (alternative delay)
philips 13 Philips
fasthp 14 HP Vectra
ibm7552 15 IBM 7552 Industrial Computer
bullmicral 16 Bull Micral 60
dell 17 Dell XBIOS
Reply 5 of 6, by Matth79
Something else weird in that config, unless you're intentionally slugging it, CPU cache is disabled - is the CMOS battery good?
Reply 6 of 6, by sd6
Thanks for the replies. I am trying to install windows 98, i know this is not ideal for a 486 machine however the idea of this is to recreate my first computer i had as a kid as best as i can. On that machine i had upgraded it to windows 98. My childhood memory was that it wasn't really any different speed wise to 95 but i expect it wont run great on a 486. I'm currently using the windows 98 boot floppy to install windows 98 with cd rom support. I will have to do some reading on the suggestions to get my head around them as this is all new to me. I assume the config.sys and himem.sys should be on the boot floppy and can be edited prior to installation.
Also regarding cpu cache, the cmos battery was flat so it kept defaulting to disabled. Fortunately its just a 3v lithium cell on this board so i replaced it and set it to enabled.
