First post, by adultlunchables
I recently started working on a Compaq Deskpro 590 (AKA 5100). I'm attempting to install a Canopus Pure3D PCI graphics card in Windows 95. The drivers install, everything seems okay... But I can't get the motherboard to disable the onboard video and push things to the card. Every time I plug the monitor's VGA cable into the graphics card, I get no display. Usually there's a jumper on the motherboard to change that, however, this motherboard has no such jumper visible or even in the manual/documentation. Is it possible that it is IMPOSSIBLE to add a graphics card to this machine?
There are ports on the motherboard for a Compaq branded 1MB video memory expansion, did they purposefully disable the ability to add a graphics card so that customers would be forced to buy their proprietary option?
Thanks in advance, guys!
Reply 1 of 12, by teleguy
Maybe it's possible to switch it in the BIOS.
Reply 2 of 12, by adultlunchables
There was an option in the BIOS to turn on "PCI Video Snoop" but no luck. I'm trying different options now. Thanks for the lead! Can you tell this is only my 2nd vintage computer build? Ha.
Reply 3 of 12, by clueless1
Canopus Pure3D is a Voodoo card. It needs a pass through cable connecting to the 2D graphics adapter. It is not intended to be used as a standalone graphics card and isn't supposed to drive the monitor when it is plugged directly into it.
More details here: Voodoo 2 Passthrough cable?
Reply 4 of 12, by adultlunchables
That makes sense, one problem though, there are no headers on the card itself... Is this accomplished by using the ports on the back of the graphics card (like where the VGA port is)? Are there any resources you can link me to in which to explain something like this?
Even if not, the help you've provided thus far is invaluable and I very much appreciate your time.
Reply 5 of 12, by clueless1
Here's a picture:
http://www.dansdata.com/images/buildpc/320/passthru.JPG
top connector in this photo is the 2D card. Bottom connector is the Voodoo. The monitor plugs into the visible connector on the Voodoo.
Reply 6 of 12, by adultlunchables
clueless1 wrote:
Here's a picture:
Do I have to have the 2D card or can this be accomplished by using the motherboard's VGA port? I have various other random PCI grapihcs cards from the same era, can I do this with any old other graphics card? (I'm guessing not, but I'm clueless at this point.)
Reply 7 of 12, by clueless1
It should work with any 2D graphics, whether it's integrated onboard, or a separate card. 😀
Reply 8 of 12, by leileilol
I'd be wary about OEM PC's PSUs.....
long live PCem
FUCK "AI"
Reply 9 of 12, by gdjacobs
Compaq was usually pretty good about having quality PSUs in their machines, although they didn't often have a big surplus of available power.
Reply 11 of 12, by Stiletto
Moved.
do the Fandango!" - Queen
Stiletto
Reply 12 of 12, by Deksor
If that's the original matrox card ... Trash it. I've got myself a Deskpro 590XL and the original graphic card was just a piece of shit. Doom ran a "smooth" as on my 486 DX33. Yeah, a pentium 90 running doom as "quickly" as a 486 !
Once it was replaced with another card, it ran pretty normal
Edit : okay I read the posts way too fast, my bad ...
