First post, by TheAbandonwareGuy
- Oldbie
This thread needed to exist. I've noticed alot of people here are trending towards mobile retro computing. So I figured I would give us a proper thread for the subject. It would also be nice to have somewhat of a review section for laptops.
Here are the basic guidelines. I can't force you to follow them and I certainly encourage adding more information but this i feel is the bare minimum for consistency through out. You must have:
1.) The laptop specs
2.) Your overall opinions of the system
3.) You opinions on the screen and speakers
4.) Your thoughts on heat output
5.) Your thoughts on battery life.
First up of course will be my own heavy-hitters.
1.) Sony Vaio PCG-V505DX
12" 1024x768 4:3 display
Microsoft Windows Millinium Edition
Intel Pentium M 1.4GHz
ATI Mobility Radeon 9200 128MB
40GB 5200 RPM PATA HDD
1GB DDR RAM
Yamaha AC-XG Audio
Intel Proset Wireless 2300AG
DVD-ROM Drive
The system overall is a solid performer with decent compatibility in terms of Windows 9x operating system. The major issues are no wireless drivers and the fact you need to sideload the drivers from the desktop Radeon 9000 to get the Mobility 9200 working. The keyboard is a little cramped but once you get used to it it's fine. The machine is also a tad bit rear heavy which can make it somewhat cumbersome despite it's relative small size.
The screen is a bottom lit LCD panel with a maximum resolution of 1024x768. It tends to be a bit brighter at the bottom due to the edge lighting technology. Aside from that it has reasonable viewing angles under average lighting conditions and could be viewed as generally responsive. With a native 4:3 aspect ratio it is ideal for the video games of the 1990s and early 2000s.
The sound system, made by Yamaha, is excellent. The built in speakers are loud and crisp and the audio jack provides an excellent sounding strong signal for headphones of all types. There doesn't appear however to be any support for hardware 3D sound which may be an issue for some however a PCMCIA slot audio device could he used to over come this short coming.
In terms of heat the machine is a fanless design which outputs minimal heat apparently sinking most of it into the bottom of the chassis. I have had no thermal related issues nor have I encountered any thermal throttling.
Battery life could be considered to be decent overall. From a full charge I can get around 2 hours run time under load in Neverwinter Nights. Given the age of the laptop I think this is a reasonable amount of time.
***** To be continued when not on mobile. *****
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
