First post, by pseudozardozz
Hello
I would like to upload a copy of the Kiss Psycho Circus demo at MoDDB, game banana, or similar gaming sites with dxgvoodoo2 preinstalled to the directory. I won't be doing anything to the original REZ(assets) container file, even the original 16 bit installers will be present in a folder with instructions not to use. I understand that the author of dxgvoodoo2 has prior obligations in regards to the software mentioned, and has full rights to say "no".
Thanks for hearing out my request
pseudozardozz
Reply 1 of 4, by stranno
Files of dgVoodoo can be redistributed freely as far as they are kept together, remain unmodified and unrenamed. Namely, only the full package can be redistributed in the form as it is!
Not sure if it means you cannot pack it or you cannot rename files. Dege will tell.
Reply 2 of 4, by Dege
Hi,
Ok, permission granted. 😀
I only ask to mention dgVoodoo briefly in the intruction guide.
Reply 3 of 4, by pseudozardozz
Dege wrote:
Hi,
Then I thank you kindly 😎 I'll post a link here so you can check on the upload as needed.
Reply 4 of 4, by Dege
Thanks!
