First post, by Kahenraz
Will the Mac version of the ATI Rage 128 Pro with DVI work on a PC with Windows?
Reply 1 of 2, by brostenen
Looks like you need to modefy.
https://arstechnica.com/civis/viewtopic.php?t=938156
EDIT:
I remember that on some Ati cards and Nvidia cards. You need to remove resistors and/or mod the teeth on the AGP connector. You need a special bios on some cards because Apple have allways wanted to lock stuff on to their platform specifically.
If all this applies to rage or just some of it, I do not recall. All I know is that you need to mod on some level.
Reply 2 of 2, by psychz
Depends. Cards with the Apple Display Connector took 25V from the AGP bus (hence the pin tape mod when converting PC cards to Mac). On the other hand, when I converted a Radeon 9250 for use with a PowerMac G4 Sawtooth without ADC support, I had to move a SMD resistor, otherwise I'd get a checkerboard-like pattern.
Stojke wrote:
